disable snmp traps identity-management
Description
Disables the identity management feature to send SNMP traps for low memory conditions.
Syntax Description
Default
No traps are sent.
Usage Guidelines
None.
The following command disables the identity management SNMP trap feature:
This command was first available in ExtremeXOS 12.4.
Platform Availability
